Power steering pump pre 81 - parts
Thank you for tracking down the correct seals..
I'm rebuilding my pump right now.. the center peice behind the impeller seems to be very well stuck in there. Was a press required to remove yours??
I've removed the backing plate and spring but there is a intermediate peice between the spring and impeller thay doesn't seems to move.. im considering use if a press..
Thoughts?
Thoughts?
Thoughts?
Thoughts?
I can confirm that it is indeed a circlip holding it together. This to prevent the rod from moving freely in or out.
