Power steering pump pre 81 - parts
Hi,
I am trying to rebuild my power steering pump of my 928S euro of 1980 since it leaked at the back through the O-ring seals.
Unfortunately the rebuildkit 928.347.921.00 does not fit my pump!
My pump is a cast iron ZF (type 7671955110) while from 1981 Porsche changed the pumps
to aluminium.
Does anyone know which rebuild kit I need.
Difference with later pump is that my seal at pulley axe is larger, and I also have other O rings.
to aluminium.
Basic Sponsor
There is no rebuild kit for the early pumps that I have found.
Take it to a local hydraulic shop and ask what they can do with it.
Or buy a rebuilt pump.
that is a shame since I want to rebuild the pump myself since it is quite easy.
Perhaps a silly question : will one of the O-rings in the rebuildkit for later pumps fit ?
it seems to have same measurements : diameter 70mm, thickness 3mm
I Like old cars, u know its will be hard find somthing looks like this. But i know nice team witch do power steering rack rebuild. Look at contact https://www.steeringlpsr.com/ and ask them about it. I recommend them
I ran into the same problem about 4 years ago. I had a rebuild kit, but the front seal was wrong. I was able to acquire the correct seal from a local power transmission company (not a car related company). They happened to have the seal in stock. The Oring I had from the kit matched, though.
I can’t read the seal size on your photo, but if you can, you may be able to find it online.
I measured the Original used O-ring of my pump : inside diameter about 68mm, outside diameter 72mm, thickness 2.5mm
The inside diameter of my pump is 67,95 mm
Do you think that new type seal is compatible with early pump?
I found both seals at a company in the Netherlands :
Company is technirub.nl
Here are the links to both Orings:
https://www.technirub.nl/o-ringen-en...0-shore-a.html
checkmate1996 (09-28-2022)
Good to see you are still going strong Gerrit! I will probably need to do this one within a few years too, thx for sharing...I have been lazy / busy last months but now starting up for some winter work on the car, going to check my injectors and try to get back into the refurbishment of the gearbox. Good luck with this one!
I will transform the plastic tubeshaped fuses to flat spaded ones like this :
