Pod foil available
Pod foil available
Its been a while since I was online with you gentlemen. I guess I had to let the "blue air" drivel pass....
Anyway, I removed my fully functional pod foil from my 1984 manual and kept it in case someone needed it & didn't want to pay over $400 for a repair kit.
The foil works perfectly and will function as designed.
Just putting it out there so that I give the opportunity for its being utilized before it goes into the spring cleaning pile of parts I cant seem to find a home for.
best regards.
best regards.
Basic Sponsor
Will not fit an 81 - only 82 to 84 all ROW & USA.
81 foil I have in stock for $329.
Thanks Roger, you had mentioned that. My mechanic took it apart and mentioned the corroded connections are the prooblem. My son's an Electronics technician and will try to fix the broken links once removed....at the moment I don't have any pod lights, speedo (was told the motor) & amperage. If he can't get it to work, I will order one.
