More meat for the 'failed smog' grinder..
#31
Received 1,542 Likes
I have been told that even our 'favorite' go-to injector refurbisher sometimes forgets this. I always remind them of this on the form when I send a set in. The normal-size bottom o-rings will not reliably seal in the intake bores. And if one or more of them don't the resulting emissions profile will look just like what's posted above.
#33
Curious... how does it not matter when they are installed in your intake? Or does RC not replace the o-rings, filters and pintle caps when they get them? You paid to have them tested only? And then you put them back in with the original o-rings?
#34
Basic Site Sponsor
Basic Site Sponsor
When I put the injectors in, during the intake refresh, they would have had the correct lower O-ring installed.
If Jeff hasn't removed or changed them, this is not an issue.
Again, pretty tough to have an S4 with CO at .10 at 1500 rpm and have much, if any, intake leak.
#35
#36
Basic Site Sponsor
Basic Site Sponsor
And I can't remember if I put in those injectors or if Jeff put them in later, so the info was for him.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#37
