928 Forum 1978-1995
Sponsored by: 928 Specialists
Headlights
Old Sep 13, 2018 | 02:10 PM
RED928's Avatar
RED928
Default Headlights
Pulled the pod and replaced the odometer gear. Put it all back together and everything is working except the headlights do not come on or move into position. The auxiliary lights (fog/side/rear) all work but not the headlights. Anything obvious I might have missed? Prior to mucking with the pod they were OK. I pulled the switch out and ensured it was connected well.
Thanks,
Steve
88 S4 Auto
Old Sep 13, 2018 | 03:02 PM
jetson8859's Avatar
jetson8859
Did you check your fuses. If you didn't disconnect your battery prior to pulling switches and putting them back in there is a good chance that an exposed part of switch touched the aluminum on back side of pod when pulling it or putting it back inand blew the fuse.
Old Sep 13, 2018 | 03:07 PM
Speedtoys's Avatar
Speedtoys
Yes, fuses.
These switches easily short as you pull them out, if you have not disconnected the battery first.
Old Sep 13, 2018 | 03:27 PM
RED928's Avatar
RED928
The battery had been disconnected. Just checked and the 15 amp fuse for the headlamp motor (#27) is fine. Any other ideas? Which of the pins on the switch control the motor?
Thanks,
Steve
Old Sep 13, 2018 | 03:29 PM
Mikebte's Avatar
Mikebte
When I reinstalled my pods I had a similar issue. What I found was when installing the head light witch, the pins on the back of the connector pushed out and had no connection. Once I removed the switch and pushed the connections on everything was peachy.
Old Sep 14, 2018 | 11:34 AM
RED928's Avatar
RED928
With the lights manually opened and the ignition switch on the headlights work fine. When turned off they retract but they do not extend normally. Ideas? Could it be the relay or something I disrupted when removing the pod? I was also removing and cleaning all the ignition wires - spark plug, rotor, coil etc. Something there I might have loosened?
Thanks,
Steve
88 S4 Auto
Old Sep 14, 2018 | 11:48 AM
RED928's Avatar
RED928
Re-seated the relay and the switch after cleaning. Seems to be working now.
Thanks for all the replies.
Steve
