RDK Bypass Surgery
The 928GT site says the part # is 928 618 150 01/00.
I am looking at a box about the size of a deck of cards, above the clutch pedal but the # is 928 618 "136" 01. Am I not looking hard enough?
Also any helpful hints on replacing the clutch arm bearing?
The part number 928 618 "136" 01 shows to be some sort of control unit
for the power mirrors. For a '91 you are still looking for the part number
928 618 150 01. Try looking more around/above the steering column.
Received 1,583 Likes
Bump on old thread because:
the guide at http://jenniskens.livedsl.nl/Technic...k%20bypass.pdf is a good but there is one fundamental problem - the box is located (at least in MY89) under steering axle, adove brake pedal and *NOT* above the bonnet release. The box in driver's footwell above bonnet release is ABS unit :-)
regards, one happy MY89 w/o RDK light
