Remove Door Rub Strip Bolt
How do get to the back of this fitting?
I can't see how to move the door seal out of the way, and I am really concerned about damaging it
Look under the weatherstripping for an 8mm nut.
That bolt and now the rub strip is toast. The bolt is a part of the rub strip.
Start looking for a good one, unless you can epoxy it back into the hole.
I should have mentioned that I have a replacement rub strip with the bolt in tact
So I need to remove the old one and then fit the new strip
Team Owner
pull the rubber out of the groove then use a socket to remove the nut IIRC it might be a 7/6mm nut
Newly painted replacement door strip fitted, very pleased with the end result
My first ever attempt at painting, so be gentle!
(I probably need to do the mirrors next)
I'm a couple of minutes away from the Ace Cafe
I occasionally go to Porsche Night
https://london.acecafe.com/monthly-meets/
Or perhaps I'll see you at the 928 Org UK 20th Anniversary later this year
Ill try to make the 20th annversary meet although probably not in the Porsche as Im in the middle of finding out what "needs minor recommissioning" means in car advert language
