Broken fifth gear - Need opinions
#32
Rennlist Sponsor
Here is a quote from the thread...
... what a dream, hearing it start up with no noise! that trannie is cooked!
Now, what to do with it. 5th gear has a bunch of chewed up teeth, but nothing really destroyed like I expected. it drives in 5th gear no problem! but no gears at all. so, all the gears you cant see below, dont connect to the 5th gear because its mating gear is destroyed.one tooth looked about 1/2 gone and the others are just jacked up quite a bit. i figure the rest of the gear box is in good shape, so maybe just a 5th gear and mating gear below??
Page 3 is where we finally find out what was wrong....once it is opened up, duh!!
https://rennlist.com/forums/928-foru...ml#post8323593
Hope that helps,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
#33
Found this one from 2011, also with 5th gear issue, not sure if it is that one...of course Mark could have more than one tranny replacement..LOL Just kidding..
Link to Thread: https://rennlist.com/forums/928-foru...-swap-out.html
Hope that helps,
Dave
Hope that helps,
Dave
This is the failure I meant:
my 84 with the stock transmission broke exactly like this on the dyno. ebrake was partially engaged, unkowingly, on the dyno, and the vibration that was felt, must have broke the 5th gear coupler exactly like the picture on the thread.
#34
Former Vendor
I've seen a large amount of worn torque tube shafts and worn splines inside 5th gear, from the two pieces moving against each other. There is generally no broken "leaves" from 5th gear, when this occurs. As I mentioned above, this is always accompanied by rust.....the metal powder that is ground off oxidizes very quickly. I've never been certain if this is an inadequacy of the clamp, or if someone left the clamp loose.
Another factor could be bearing migration or shaft harmonics. I can envision the driveshaft moving in a "wave" at that end of the shaft, in either scenario. No amount of clamping is going to keep the two parts (driveshaft and 5th gear) from moving in relationship to each other. I firmly believe that Porsche knew what they were doing when they installed the damper into the torque tube, near the rear, which helped absorbed these harmonics. As the energy transfer pieces wear (the rubber deteriorates) the harmonics of the shaft will increase. And of course, the current trend to just remove the damper is a terrible idea, in my mind. (Read what Porsche went through to engineer the "fast shaft" in Project 928.)
Broken "leaves" are rarely associated with rust. I think that this damage generally occurs on disassembly or re-assembly. (I can also see this happening from harmonics.) I believe that these "leaves" can be fractured and not completely separate until a later day.....although most breaks are "clean" without any evidence of initial cracking. (Although it is tough to tell much from a picture, it appears that the one in this post is "clean".
#35
The only other break I've seen that was identical to this was on an 90 S4 automatic rear flex plate. The customer complained of a rattle. Previous history on that car was a monster of a rear end hit that cracked the front upper bell housing, both transmission mounts and differential cover. In a testament to how stout our cars are it drove straight as an arrow. The drive shaft in the torque tube was quite loose and the splines were so worn that Mark held back the core charge.
#36
Novice question: Does 5th gear determine 928 Final Drive ratio?
#37
Chronic Tool Dropper
No. In top gear, the drive passes straight through to the pinion. It's the R&P ratio from there.
#38
And that is in the differential.
Thanks for the clarification, dr bob. (got it right this time.)
#39
Per the PO: "It worked fine before it broke. It broke after I merged onto the highway and shifted into top gear - I wasn't even driving it hard . I think think had about 110k miles on it when that happened."
