The GWS gets a fresh interior
Developer
It's been 8 years since the racecar was painted, and 8 years of racing including 3 years at the Bonneville Salt Flats have made a mess of it.
Michael Price from our staff took it to task and here are the results. Thanks Mike!
Here are some before-and-after pics.
Looks great.
Did you ever figure out why the Conti belt snapped on your last outing?
Rennlist Sponsor
Lookging good, it's always great when the fix is nothing more than what a new coat of white paint can't fix! LOL
All the best,
Dave
Rennlist Sponsor
Rennlist Sponsor
It was sorta tongue cheek, hence the smiley face. It could just be the fact it is a Conti belt, I would guess with all of Carl's vast experience and racer's mentality of continually improving, he knows what the issue is/was and is addressing it more than any of us could help.
In reality, it seems like an odd "hijack" to an interior paint thread, but that is the wonder of Rennlist!! LOL
Cheers to you,
Dave
Hi Swaybar,
Cheers to you,
Dave
Cheers to you,
Dave
Developer
There are two suggestions and I am looking at both of them: 1) is using a stronger belt, and 2) is adding an idler in the large span between the water pump and the left head to prevent the harmonic wave from being so great. An examination of the valve train shows that the span from the water pump to the right cam is actually the longest, and it has a anti-harmonic idler already mounted on the toothed side. The second-longest span is from water pump to left cam, and it has no such protection. They encouraged me to install an idler on the smooth side within that span. We believe this is where the harmonic wave when I switched from accel to decel became the greatest, and the Gates engineers told me that wave will break belt fibers as neatly as folding a belt will.
Conversely, when a timing belt is torn apart by too much tension, it tears in an oblique line that usually involves 8 or 10 teeth, they said. So no, we do not think this was caused by running high-lift cams or high valve spring rates.
Folded pre-install was the only thing we could think of also. Hope the damage wasn't too bad.
Rennlist Sponsor
If there is anything to share I am sure Carl will share when he feels the time is right. In over 2 decades I have never seen Carl be shy about sharing his info. He has shared all the good and the bad for others to use for their 928s. In reality he is pushing the limits with 928 Performance Developments, you know Racing Improves the Breed thingy. What he does is a far cry from just replacing a damaged or worn part and has probably advanced 928 enhancement as much as anyone, and much more that most
Bad to the white paint topic, Carl what kind of paint did he use, expoxy?
Cheers,
Dave
Developer
Dave, just Hardware Store Rustoleum Oil based paint and a paint brush. Easy to touch-up later and still have it match. The paint that "failed" was automotive spray paint, done at the time when the car was painted in 2010.
Developer
Rennlist Sponsor
Well, as you are fully aware, Sometimes the Truth Hurts....and Sometimes it FEELS GOOD!!!
All the best to you and your Family,
Dave
