86.5 Engine Harness 14 pin help
I got the new 14 pin connector to finish the engine harness on the tan 86.5. The problem that I'm running into is that neither of my 86.5s seem to match the vehicle wiring diagram for 86 or any of the diagrams I've found here when it comes to the intake temp switch. The diagrams say that pin 13 should have the red/green wire for it (which both of mine to), but they also say pin 12 should have the green wire for it. Neither car has pin 12 populated on either side of the connector. The blue car has pin 10 populated (with a brown wire) and the tan car has a green wire for the switch and I think it was in pin 10 (nothing in pin 12 on the female side, and my male side was destroyed).
So I'm assuming I'll be ok to just put the other switch wire in pin 10, but wanted to check and see if anyone knew why both of these cars don't match the diagrams.
Blue car
![Name: 9ELDqWG.jpg
Size: 848.8 KB](https://rennlist.com/forums/attachments/928-forum/1350370d1683258066-86-5-engine-harness-14-pin-help-9eldqwg.jpg)
My new wiring for tan car. Yes I know the colors don't all match, I screwed up ordering some of the wiring. I do have labels with the correct colors on the wires though.
![Name: qfpyZox.jpg
Size: 1,006.3 KB](https://rennlist.com/forums/attachments/928-forum/1350371d1683258066-86-5-engine-harness-14-pin-help-qfpyzox.jpg)
Wiring diagrams.
![Name: k0KIjfV.jpg
Size: 84.9 KB](https://rennlist.com/forums/attachments/928-forum/1350372d1683258066-86-5-engine-harness-14-pin-help-k0kijfv.jpg)
And the other diagrams I've been looking at:
https://rennlist.com/forums/928-foru...ctor-help.html
Blue car
![Name: 9ELDqWG.jpg
![Name: qfpyZox.jpg
Wiring diagrams.
![Name: k0KIjfV.jpg
