Ground strap from r/h ignition coil bracket
I have a 1988 S4 and am changing the distributor caps and rotors. I noticed a ground strap from the r/h ignition coil mounting bracket that isn't attached to anything on the other end. The left hand coil bracket has a ground strap which mounts to the cylinder head behind the TB. I looked below the r/h cam cover area but couldn't find a mounting point for the ground strap, where does it mount too?
Right side should bolt to the lift point.
Yes near the hall sender. There's a 10mm nut on the lift point.
