Paging Seth......Connecter Help Please
Hi Seth,
I saw your thread where you were doing the injector connectors etc. Did you do the TPS 3 pin connector as well? If you did, can you point me to the correct wire color for each pin. Some bozo (errr...me) managed to throw away my drawing.
Cheers
Scott
Cheers
Scott
(earth rumbles...dirt and soil part as a hunched form slowly rises from the depths)
'in a deep, sepulchral voice, "You rang?"
Hi DeWolf! Got you covered:
Old connector. White/red tracer on left, brown in middle, white on right. Note position of locking wire for correct orientation of wiring in plug.
See 'throttle valve switch'. Terminal 2 is 'ws' which is white, terminal 1 is 'br' which is brown, and terminal 3 is 'ws/rt' which is white with red stripe.
Good Luck!
Good Luck!
