928 Forum 1978-1995
Sponsored by: 928 Specialists
Wheel alignment specs
Old 05-14-2018, 01:38 PM
85fortheDrive
Artist Formerly Known As 84totheFloor
85fortheDrive's Avatar
Default Wheel alignment specs
85 Auto
Having a wheel alignment done in the hopes of silencing the steering wheel chatter at 80+ mph. Found this in the WSM, but the print date for my PDF manuals is 1993. Wondering if these values are correct for the 1985S.
Thanks for any help!
Peace,
Tim
Old 05-14-2018, 01:42 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,077 Likes on 1,186 Posts
Wheel chatter - how old are the tires, there should be a date code on the sidewall:
If they are new enough to keep, try getting at least the fronts re-balanced at a shop with a Road Force balancer.
As to the alignment, pay close attention to the other page which addresses lifting the car and re-settling the suspension before doing the alignment. The common way to deal with this is find an alignment shop that doesn't have to lift the car first.
However, still need to be 100% sure the nose is settled before taking it over there. This can take a couple hundred or so miles, depends on the car.
Old 05-14-2018, 01:57 PM
Adamant1971
Adamant1971's Avatar
Have you had them road force balanced? If not I would try that first and insist on seeing a copy of the report, anything above 15lbs can cause vibrations in my experience.
Old 05-14-2018, 02:45 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
What does a WF balance report look like?
Old 05-14-2018, 02:54 PM
Adamant1971
A road force report will show a road force number for each wheel, the optimal wheel location and pull (if any). Below 10lb is excellent, anything under 15lb will be smooth. I have found if you don't get a copy it usually means it wasn't done.
https://rennlist.com/forums/rennlist...ce-report.html
Old 05-14-2018, 03:32 PM
85fortheDrive
Thanks Hacker and Adamant. Rear wheels have a final four date digit of 1416 - good tread left. The front wheels, not so great. 2109 and pretty worn. Will need to inquire about replacements for those.
Quick Reply: Wheel alignment specs
