Quick torque spec check: 5 spd intermediate plate to ring gear?
I have 110-130 ft lb, is that really correct for these little 11mm bolts? Seems a heck of a lot but this would be an expensive thing to get wrong.
I have a more normal spec for pp to flywheel, is 21 ft lb correct?
thanks in advance
thanks in advance
Received 1,543 Likes
WSM says clutch/flywheel is 22 N-m / 16 ft-lbs.
Archive Gatekeeper
WSM, page 30-06a, starter ring to intermediate plate, M7 bolts, 10 ft-lbs.
So I can add them to the torque specs spreadsheet, how long are the bolts?
EDIT- NM, M7 x18, '78-'79 only.
For dual-disk the specs are 15 N-m for M7 bolts for the intermediate plate and 22 N-m for the plate to flywheel.
These from the 85-89 Spec book page 51.
Thanks, that makes more sense, I got those crazy numbers from a search on here...be careful out there. Sorry not to mention the MY, its an early 79 (0057) Euro.
edit: Yes I should get a copy of the WSM!
