928 Forum 1978-1995
Sponsored by: 928 Specialists
86.5 Instrument Cluster Foil.
Old 02-15-2018, 05:44 AM
DeWolf
DeWolf's Avatar
Default 86.5 Instrument Cluster Foil.
Hi Guys,
Found a new foil locally for $50.00. Is it brand new. Mine has a small tear that has been soldered and I've noticed that a couple of connectors are looking dodgy as well. Is there any tricks I should know before I attempt the foil transfer?
cheers
Scott
Old 02-16-2018, 09:52 AM
Crumpler
Crumpler's Avatar
Originally Posted by DeWolf
Hi Guys,
cheers
Scott
Hey Scott, I did this last year.
Just label everything you take off, and try not to get sucked into a rabbit hole on other pod restoration while you are doing it.
The new circuit is awkward to fold into the tab shape it requires to fit into the muti-port connectors for the harness wiring, so watch that part.
I don't remember what I paid, but 50 bucks sounds like a great deal.
Old 02-16-2018, 10:56 AM
SeanR
SeanR's Avatar
Take a picture of the cluster before disassembly and refer to it if you get confused.
Old 02-16-2018, 11:34 AM
Wisconsin Joe
Wisconsin Joe's Avatar
IIRC, Dwayne's writeup on the speedo has instructions for removing and installing the plastic.
Quick Reply: 86.5 Instrument Cluster Foil.
