pulse ground to injectors
'84 Euro computers got wet. Have replaced the computers but can't seem to get the pulse ground to the injectors. Any ideas anybody?
I would suspect that "maybe" some other connectors/relays/fuses also got wet as well ? Maybe there are some corroded connections ?
Do you get spark ?
Do you get spark ?
All the fuses have been replaced. I will check the LH relay. Yes, there is spark, but no gas. Water just dripped in from the top after washing the winshield with a hose. Doh!!!
