Headlight delete
#32
Something like this might work. I just need to figure out the math for where to mount the actuator and base of the front bracket, and the necessary length of part "A" in this picture. Part "B" would just be the rod of the actuator.
hernanca (12-22-2020)
#33
I'm going for a different solution to the same type of problem : I'm on a weight loss programe for a rally car - so losing that heavy motor for the lights .... is a must do. My solution (at this stage) is to have a mechanical system , and to "lock" the lights either up or down - mechanically (probably with a bolt !!). The original swivel mechanism works reasonably well , and compared to the motor is light ... so I may end up using that. There is some scope for weight reduction further - by simpliflying the actual headlight unit itself (I have bought two plastic cased motorcycle lights to try and use those .... too soon to say , but I think it's a workable solution).
#34
Actually, I'm going to try just a linear actuator mounted where part "B" is. it pivots on both ends, so I can get one that has a 6"-8" retracted length and 4" stroke. If I mount it in the right location to the bottom of the headlight bucket and to the underside of the lid, it should work. I will add a decent spring on each side of the lid to pull down when extended and hopefully that will keep it motionless.
#35
Brett,
How about this? Spring loaded with the default as headlights are up. The springs hold the headlights up so they don't bounce. The motor is actually used to retract them.
Another thought: Don't the older style Euros use a driving light in the bumper? Maybe that could assist in your night time vision issue.
#36
Brett,
I'll try both ways to see what works best.
#39
