steering shaft issue
the splined, threaded steering wheel shaft on my 928 will not allow me to install an aftermarket MOMO wheel and adapter I have. the splined portion of the shaft sits slightly recessed in the steering wheel column. If I put the nut on the end of the shaft and pull, I can get the splines to protrude further, but when I release the shaft, it returns to its original shorter state.
Can I adjust this end of the shaft, perhaps from the firewall to allow more of it to push through?
James
James
I'm having a hard time picturing what you're saying.
When I installed mine, I used this adapter and it worked perfectly (I just needed a new washer): http://www.ogracing.com/sparco-steer...-928-912s-911s
threads do not protrude far enough through the aftermarket hub for me to put a nut on it. The shaft splines are partially recessed in the steering column.
James
James
Team Owner
you need to get the correct 928 MOMO hub adapter .
the shaft is spring loaded and thus not adjustable,
messing with the shaft will usually result in damaging the upper bearing.
Administrator - "Tyson"
What model Momo adapter do you have? Just because it fits the splines doesn't mean it's the correct one.
See this thread:
https://rennlist.com/forums/928-foru...oesnt-fit.html
See this thread:
Team Owner
please post a picture of the protruding splines without the hub adapter ,
maybe the E clip has fallen off or the upper bearing has already failed
