For Sale - Custom 32v Intake
Developer
C'mon guys! It's a proven and tested performer!
For those of you that are interested in running it with the stock LH and EZK and MAF: what I would do is mount your throttle body direct to the TB mounting plate as shown, the come up a little and turn 90 degrees to the right or left with a silicone elbow, then just insert your MAF into the hose and plug it in. By turning a 90 between the TB and the MAF you should clear the firewall easily.
Developer
Yes, simply be sure that the TB you select has a TPS mount on it. Then, make sure that the TPS that you use is compatible with the engine management you use, and you are good-to-go.
Developer
We make an adapter that mounts a modern TPS to a 928 throttle body. Here is a pic of it.
You may be able to use that same adapter to mount the Porsche TBS to a LS throttle body.
Administrator - "Tyson"
Something like this would work to go after the throttle body. Mated with the Alpha-N modification for the Shark Tuner to eliminate the MAF.
Fabspeed Intake Plenum for the 911's:
https://rennlist.com/forums/parts-ma...d-exhaust.html
Rainman
3.5" in/out, about $10...
