Sunroof Crank handle....?
In a pinch you can use a belt or strap and run it over the rubber clutch (#41) and pull down and apply light pressure as you pull the strap to one side or the other for either opening or closing. Works really quickly this way.
Ken --
Look at #42 in the exploded sunroof parts diagram here. The larger speed-handle tool you are looking at is the power-seat tool, and that one does fit in the tool panel. The sunroof crank has a little thumb-nut that attaches the tool to the drive motor after removing the cover. It's maybe 3-4" long.
https://rennlist.com/forums/attachme...crank_0001.jpg
Ken
80 928 S
5 Speed
UK
