oil cooler lines pressure
Team Owner
these lines have to hold about 90 PSI
But get more.
These lines are pressure-regulated and see 5 Bar (75 psi), or a bit more, a lot. The hose is rated for "burst pressure." Get at least 200 psi as a safety measure. And note that leaking at the fittings is the most likely failure.
