Quarter window out pre-reinstall questions
Team Owner
I use a syringe to inject the DC111 into the window seal to chassis. along the lower edge of the window.
if the window is already installed otherwise wipe the inner area where the seal sits to add a vapor barrier to protect the painted surfaces.
On these seals water can stay in the lower area for many days before it ever evaporates.
The DC 111 will also add a lubricating effect when installing the window seal.
The idea is to prevent water from getting through the painted area so corrosion can begin again.
NOTE as a temporary you could also wipe the DC111 onto the rusted area and it will stop the corrosion as it provides a water barrier, this till the metal can be properly prepared and a new painted surface is applied.
The DC111 is also good for any rubber seals on the car as it will rejuvenate them.
This also works well on The lower door edge seals if they are not cracked they can be brought back put a smear on them then let sit in the sun it will assist in the DC111 absorbing into the rubber.
Keep it off the window so it wont crate streaks.
NOTE with DC111 applied you may notice streaks from water rinsing the sealant down the paint this removes easily with spray detailer.
NOTE use the DC 111 on the rear lock grommet surround and the wiper pivot seals, works great for keeping out the water.
Administrator - "Tyson"
I'm not looking forward to removing the other 1/4 window but I'm going to anyway anticipating it looks similar. Fix it now before it spreads.
This is a one owner car since 1983 (was a SoCal car from 80-83) and lived in a climate controlled garage.
This tool makes short work of the sealant.
https://www.zoro.com/westward-drill-...iABEgLcAvD_BwE
Avail at Northern tool also. Note, get the short bristle type which will not damage surrounding metal.
THIS THREAD BROUGHT TO YOU BY
DOW CORNING
FEATURING DOW CORNING DC111 AN ESSENTIAL PRODUCT FOR YOUR PORSCHE 928.
product endorsements are not a reflection of Internet Brands marketing program, personal or professional opinions or actually something that they would say. But use it, it's good ****.
DOW CORNING
Team Owner
NOTE I also use DC 111 on the master cylinder base seal to the booster and the grommet bores,
this will prevent water migration and thus the MC failing due to corroded grommets and a leaking tank.
Smear the grommets and the bores with DC 111 and they will not rust ,
the MC tank gets wet every time the hood gets wet,
the water runs down the tank and will wick into the grommets,
the DC 111 will prevent water from entering
The black vinyl is factory and is necessary due to the design of the early interior quarters. It covers the insulation. Mine shrunk as well and I replaced it with domestic grainy vinyl. On one of my parts cars, it was wrapped around the window channel on my 79, it appears to be under the interior rubber lip only.
To reglue the vinyl, use Weldwood Landau Top and trim contact cement. Don't use the spray stuff or any consumer grade product. This area gets a lot of sun exposure and heat and the consumer products don't hold up. Ask me how I know!!
Good luck!!
Good luck!!
I hate glazing compound used for quarter windows- I'm about 2 hours into removing that black crap from the quarter window channels of an '89 I'm working on, the only thing that touches it is a 3M stripe-off wheel. In about 7 cars' worth of quarter window R&R's, only 2 had goop on them and those windows had been out before. There's no reason to use any of that crap, it ruins a $200+ gasket that's otherwise often re-usable. A clean window frame (the vinyl does fold over the metal edge of the channel before installation) and careful installation makes for a watertight seal (Though perhaps I'd feel differently if I lived where it rains (?) ).
Question- is the DC111 being used primarily as a lubricant or a water-sealant for installation? I prefer P90 THX to lubricate the gasket for installation.
bump...
im at this stage now. Ive read so many different ways to do it all.
I like the new seal and clean frame approach....with lubrication to help with installation.
as always. Good stuff Rob
