Size of nuts for rear AC controls?
I'm putting my center console back together, it came in boxes when I bought the car. I'm down to getting the rear AC controls back in, but I don't have the nuts to secure them to the center console. Does anyone know what size they are? I've found 6mm radio shaft nuts online, but not sure if they would work or not. Thanks.
Archive Gatekeeper
You're looking for the metal rings immediately under the *****? They're part # 911 613 119 02, and are used on 78-89 911s as well.
99% sure they're bigger than M6 in ID, I should have a spare here somewhere, will find one and measure it.
![](https://webfiles.uci.edu/redwards/public/Hebert%20console%20clock%20and%20AC%20pots%20exploded%20view%20%232%2011-12-11.jpg)
Archive Gatekeeper
Too late. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
OD 20 mm:
![](https://webfiles.uci.edu/redwards/public/Rear%20AC%20switch%20metal%20rosette%20OD%2020%20mm%209-5-17.jpg)
Close to M10, though it won't thread either on M10x1.5 or M10 x 1.25.
OD 20 mm:
![](https://webfiles.uci.edu/redwards/public/Rear%20AC%20switch%20metal%20rosette%20ID%208-8%20mm%209-5-17.jpg)
