928S Steering Rack rebuild question.
Purchased steering rack re-build kit and have an issue with blue nylon bushing. The new piece goes over a o'ring and is thicker than the stock piece. Has anyone had this problem?
From: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
From my old thread on this problem
. I rebuilt the steering rack with a kit from Rennbay. Everything went good and I will cross my fingers that it doesn't leak. A couple of seals were wrong in the kit. They were the ones on the center part of the shaft that seals the left side from the right. I probably didn't need to replace these seals(plastic and o-ring under) but I had already cut them off. I was able to find the seals at an aircraft seal supply place run by an old couple. They let/helped me look through the building until I found something that would work. I had to grind(Dremel) the non-critical inside diameter some to make this Delrin seal fit over its carrier. The rack boots were a struggle to install especially when my hands got tired from the struggle.
I have extras that have not been dremeled out. You would have to do that. PM me the measurements of the old one and your address and I'll put one on the mail if needed. Gunar
Thanks for the info.
Thanks for the offer. I am going to reach out to Carl at 928 motorsports during the week and ask him what is going on and if I cant get it figured out, then I will reach out to you.
The reason you may end up with extra unused seals is the seal kit fits several models and years of pumps.
I have no other bushing of the type that you are showing, either. The blue bushing should be the right one and sure looks like it isn't. If you could give me dimensions of your used nylon bushing, I would be happy to call around for you.
so when you rebuild the racks, you either don't replace the o'ring / Teflon washer or haven't come across the blue Teflon washer? The blue Teflon washer fits nicely without the o'ring, but I would think it would leak with out the o'ring.I have a call into Rennbay, waiting to hear what they say as well.
I do not rebuild the steering racks. We sub that out to a specialist, and he does not use this kit, so I am sorry i cannot tell you what seal he would use in this situation.
I like that you called Travis at Rennbay, and I think the answer is correct that the blue bushing provided replaces the two parts. Travis will know.
