LAGUNA SECA SCCA RACE Sept 2nd, 2017 this weekend!
LAGUNA SECA SCCA RACE Sept 2nd, 2017 -VIDEO UP
We have our last SCCA Laguna Seca Race this coming weekend and its a little light as far as sign ups. great opportunity to come out and race ( ahem, PETTY!! )
i think there is BMW Racing group with USTCC to fill one of the run groups, but in the open class groups there is still room for more.
practice and qualify on Friday , race 1 on Saturday at around 12pm.
stop by around lunch on Saturday and say hello if you are in town
going to test out the new rear wheel bearing!
Mark
https://www.motorsportreg.com/events...na-seca-039943
Mark
so we are on the 5th race now. Geba water pump stilll running strong with no leaks . all the horror stories of the pump are making me worry. i was talking to someone that said that the Geba pump is better than the laso.. it is made in germany too. true? what is the problem with the geba? also, keep in mind, i had a porsche factory pump go bad too. nothing is safe!!
Originally Posted by mark kibort
That will be great! let me know if you want to meet up for dinner. Ill have my side kick with me!
Hey Mark! So what time will your race be on Saturday now? Would love to see a race in person. Will confirm if I can make it! BTW how much do they charge to get in?
Cheers,
Rick
Cheers,
Rick
Hi Rick.. no charge.. the race is free. bring a bike too if you can, easier to run around the paddock and maybe up to the corkscrew.
It would be great to see you out there.
Mark
Mark
Should be HOT this saturday as well 90 degrees + ............lets see how the Geba water pump works and a properly bled cooling system. ill be video taping gauges during the race.
Mark if squeezing your hose makes you feel better...go for it !! But Porsche made the 928 a self bleeding system unlike the 944 which IS FITTED WITH A BLEED SCREW.
You still running your belt tensioner without oil ?? the need for oil came up on another thread.
now, if it was self bleeding, the porsche factory folks wouldnt have mounted not 1, but 2 bleed fittings to the upper cooling manifolds on the Holbert car. (or would they just do that for fun?) anyway, the bottom of the reservoior is NOT the highest point. the top of the engine where the water exits the engine is.
as far as tensioner oil (or detensioner oil). no, there is residual oil in there, but just enough to keep rust from forming. its job is to help distribute heat to the tensioner from the block... without it, it takes longer, so i wait to do any redline activity until the entire engine and transmission is fully heat soaked. (oil at 180f min) what was the thread about ? what were the conclusions?
Mark -- Wife n I will be there with bikes -- we can enjoy some time in Monterey/Carmel AND a car race, what's not to like? :-P
You're in the 5th race... and first race about noon... so about what approximate time is the 5th race? If it's later in the afternoon we might just show up for your race!
Cheers
Rick
Cheers
Rick
Great! Our race is at noon on Saturday.... don't know what number race of the day.. 5th sounds about right. I have to get out to get kids for labor day activities so its a short weekend for racing.
PM me and ill give you my cell.
see you there.
Mark
see you there.
Mark
Cheers
Rick
Cheers
Rick
Here is what the factory mounted on the holbert car for bleeding. they must have also known about the issue. BUT, opening the overflow and squeezing repeatably all the air out of the lines works perfectly.
keep in mind, this is the highest part of the cooling system, NOT the bottom of the overflow container as some have said.
