928 Forum 1978-1995
Sponsored by: 928 Specialists
93 GTS Top End Refresh
Old 09-11-2017 | 05:20 PM
  #31
BC's Avatar
BC
I have done it both ways and it does look a bit strange depending on the PC'ing.
May as well just make it easier on ourselves and not coat them.
Old 09-11-2017 | 06:13 PM
  #32
Alan's Avatar
Alan
Electron Wrangler
Originally Posted by jetson8859
I'm not installing a GB oil fill plate so no worries there. Going to use the paper gasket and Honda bond, but definitely good to know for future reference.
You talk about surprise at the amount of oil in the intake & TB. Here is your chance to start addressing that - fit Greg's separator plate - on a GTS I think its crazy not to - you are going to need all the help you can get. I'd also fit the separator version to all the head PCV ports (and in fact plumb all 4) you will come up with ways to use them later to create a better PCV system - its ~cheap to do it right now. Again you are going to need all the help you can get. Seal the head cover and head cover PCV ports really well. Personally I'd also drill out all the PCV elbows to full size - but you need to decide what you want to do there.
Alan
Old 09-16-2017 | 11:25 PM
  #33
jetson8859's Avatar
jetson8859
I appreciate all the comments regarding the powder coating and oil consumption. Have had a busy few weeks at work but was able to get back to the car this week.
I used a Dremel with wire wheel and removed the powder coating on all bolt mating surfaces as well as the hose nozzles so am hopeful that this alleviates any electrical connectivity issues.
To address the oil issues, I​​​ installed Gregg Browns oil baffle, drilled out all the elbows to full size, added another elbow to the drivers side as well as oil separators to both front elbows. The passenger side front requires a slight modification to allow the separator to fit (see photo)
I added the newer hose from the passenger side "Y" connector at base of MAF to the oil fill neck.
Also added GB fuel lines front and rear as well as new TPS, knock sensors, flappy bearings and had injectors cleaned.
Hopefully have her all buttoned up tomorrow and ready for Frenzy!
Old 09-17-2017 | 07:23 PM
  #34
Bigfoot928's Avatar
Bigfoot928
my 90 model Stock untouched 39K S4 was found to have an intake coating found in 1997 that was flaking off during a engine reseal job because the car sat 5 years and was leaking from every possible seal. I had a service contract and also was part owner in a shop that had been working on Porsche, BMW's and Mercedes since the 70's. My shop partner had owned several 928's and had many (rare at that time) 928 tools..... we sent the intake to DEVEK at the time as they were the intake experts... 400 miles after assembly the engine ate itself. the oil was full of glass media and metal flake.. from the intake refresh..... be afraid... very afraid.... in the following years my 928 gobbled up 100k... in some ways I wish I never bought it.... the only regret.... was the money... I met the best people of my life.... and now I am part of this wonderful family... except Hacker is that cousin that everyone denies being related to... and RandyV because of that shower pic with Normy...
Old 09-24-2017 | 09:20 PM
  #35
jetson8859's Avatar
jetson8859
Finished up the top end refresh this weekend. Had an issue fans not coming on during initial shakedown drive, after following troubleshooting found fan amplifier not working right, swapped in the one from 87 and she is running great. Took about a 45 minute drive on both interstate and stop and go and temp stayed right on the right side of the zero in the 170. I believe she is already for the trip up to Frenzy. I appreciate all the help and guidance!
Old 09-24-2017 | 10:56 PM
  #36
Mrmerlin's Avatar
Mrmerlin
Team Owner
nice job keep em flying!
Old 09-25-2017 | 11:18 AM
  #37
Chris Lockhart's Avatar
Chris Lockhart
Looks great Kevin. Nice job.
Old 09-25-2017 | 01:45 PM
  #38
SeanR's Avatar
SeanR
Looks great. See ya at Frenzy.
Old 11-13-2022 | 07:06 AM
  #39
SecaBlue's Avatar
SecaBlue
Nice! Just curious to revive this post... what km/miles were on your GTS engine before doing this?
Old 11-15-2022 | 02:23 AM
  #40
jetson8859's Avatar
jetson8859
There was approx 132,000 miles on the car.
SecaBlue (11-15-2022)
Old 11-15-2022 | 05:44 AM
  #41
SecaBlue's Avatar
SecaBlue
Quick Reply: 93 GTS Top End Refresh
