quick wheel question
Depends on the offset of the wheel. If they are 911 offset ie 52-55mm, a 225 section tire is the largest in front. With a proper 928 front offset ie 63-65mm, you could use a 245 section tire. The rear is more forgiving, I have 275's on a 17x10 inch wheel. You would probably have to roll the fender lips for clearance though, 265's should fit without any mods.
front tire inside gap to fender lip pic
TIRES 225/40/18 wrong size on other thread before
Rims 18x8 with backspacing at 47mm
Suspension: bilsteins coilovers adjusted 13 full turns up with eibach springs
Tire wear on fender lip is from me riding all the way down before i adjusted
rear tire to fender lip
Tire: 285/30/18
Rim:18x9.5 with 53mm offset
Suspension: bilstein coilovers adjusted 7.5 turns up with eibach springs
does not rub believe me i just cant get my finger between tire and lip, also no spacers on hub
Tire: 285/30/18
