I don't have bandwith to deal with shipping of any of this.
Will take one shot here at putting S parts in enthusiasts hands for a fair price. Come yourself or send a surrogate! Am close to I80/90, approx 30 mi due east of south bend/notre dame. Easy run from chicago, detroit or columbus, or louisville.
Uncut Nosecone --$60 (on my spoiler delete 85)
Tailcones USA (4) -- $50 ea (2xWhite,Platinum, Meteor)
S Front Calipers -- $40 pr (2 sets)
S spindles & Hubs -- $40 per pr (2 sets) (1 w/antilock, 1 w/o)
sold Front antisway bars w/links -- $35 ea
S Lower control arms, 2 pr -- $40 /pr,
S-upper control arms 1 pr -- $40
sold 2 Steering racks, both worked and didn't leak ($70 both)
sold 1 steering column from wheel to aluminum knuckle (at rack) $50
sold S car Cross members (2) w/ m mounts, $25 each
sold 2 known good radiators, $30ea.
sold 1 Power steering pump with 86 mount. 40
sold 32v engine block, pan, heads still.on it $125
sold 85 CE panel, known good, some broken tabs but works great and plug lock works, so perfectly useable, includes most relays.60
sold 1 mid year bellypan, usable $40
sold 1 pair of decent S-3 plastic intake tubes $50 pr
(To sweeten the deal)
sold 5 speed t tube, good splines, could use brgs, $30
sold 5 speed pedals incl clutch linkage. $20
sold 5 speed clutch master and slave and pipe. $15
Sunroof innards, cables in tubes, parts, motor, transmission and coupler $50
From excellent working sunroof.
Quarter, door and hatch glass 75 all
Driver's front fender --- $50
Platinum Metallic Hood --$100
White 85 door shells -- $40 ea
Pair 86 seats, black very good, fully operable, $375
sold Oil Filler neck, 32V, Cast metal version, $75 with cap and baffle at base.
sold Known good Fuel tank w/ gas cap -- $125, good fuel pump incl.
sold S-3 Organ pipe set with throttle body, $125
(2) 1984 manual trans cores $100 for pair, must take both.
(one is Euro layshaft "07", grinding in 1/2; other is USA "08" shifted good but popped out of 4th.)
Box of clean 84 auto trans innards, plus open differential, plus new gasket set -- (free, includes me praying for you)
S4 open diffy, kept very clean, $35
Rear quarters, black vinyl, appear to be re-covered but are very nice $75 pr
Black Headliner, vgc. 2 pieces, $40
Complete 86 exhaust, duals that run side by side, bolt it up, $100 Can be used on a 16v car too with no adapters ( unless you have upgraded to the SS tubular headers, then you need a spacer)
86.5 exhaust center section (pipes with split resonators) $50 (and you can have the cats too / turn them in for platinum or palladium)
sold Dual clutch, pplt, int plt, discs, tube, worked but getting worn, remember Motorsports will pay for intermediate plates...$100
Much other stuff..... 84 5 speed rear axle carrier with hubs and axles; 85 automatic rear axle carrier with hubs -- $60 each
2 pod cores, $25 ea.
2 pod cores stripped to the aluminum inner $15 ea
Complete heater core / evaporator unit. $40
Rear air unit from 86.5 $25
Black door cards, 86, $30 pr.
PM me, we talk, set up time to come here.
Pay, load, enjoy.
Am running out of time, so needs to happen pretty quick
Talk about it openly, come yourself, build a group.... Take it lock stock and barrel -- will make you a good deal
Chris
Reason: Added stuff
Can you post some pics of the headliner? The one in my '82 is all fubared, and I'd love to get another one. I'm heading up to your neck of the woods next weekend, so could probably swing by on Saturday.
If you want to drag any of those parts with you on your way down to Md you'll pass right by me on i95 (se pa/n de). I'd like those trans cores and manual hubs/axles, maybe some other stuff.
Just a quick thank you to the Toft family for their hospitality yesterday.
Pleasure meeting you in person Chris, and thank you again for the extra parts.
You are a true asset to our community.
Were you in the Maryland area two or so weekends ago? I was in my 928 and I rolled up behind another in Silver Spring that looked like yours. Took me by surprise as it was the only 928 I've seen driven on the streets in a couple of years.
Thanks to Mr Crumpler, Mr Byrd and Ryan, and Brad, many of the parts will live-on.
Meanwhile, the 85 frame/shell and most large remaining parts (nobody (wanted the body parts!) are headed to an obscure multiacre warehouse of a Porsche guy, where they will literally be placed on a shelf.
It isn't exactly "Ark of the Covenant" caliber, but is a similar situation nonetheless.
(We are still thinking about using a section through the entire hatch/tail to create ***-end wall art, with working taillights. But judgement of the new steward is that would be sacrilegious)
Plus, along with his S4, he has twin turbo 996 cars...and says that "that's real ****".
Avar, no, not in Silver Springs recently with 928, but headed your way!
Two reds and a brown will make the trip. Probably. ( I need at least one for Frenzy-ing next month!)
The grey Euro in the avatar is now owned by Ed of Guardian water pump fame.
