928 Forum 1978-1995
Sponsored by: 928 Specialists
Traumatic experience today !!
Old Nov 25, 2003 | 01:38 AM
Bernie's Avatar
Bernie
Hey Donald,
I actually experienced neither over or understeer?
I lifted throttle at the entrance of the turn as a instinctive "panic" move, caught myself in the act and got into the throttle again at the apex...
I felt completely neutral in a 4-wheel drift through the turn...
At least I think I was neutral.....lol
To be honest, since I have never felt a drift like that before, I can only assume that's what happened?
All tires screaming?
No Oversteer?
No Understeer?
Kept shiny side up?
What would you call it?
Old Nov 25, 2003 | 01:42 PM
Rufus Sanders's Avatar
Rufus Sanders
Lizard and John S.,
Yes I hear exacly what you both are saying, and that is the same answer I would give to the question too. Althought I live close enough to a track to make it worth the while ( 3-4 hr. drive?) occasionally, I'd rather spend 3-4 hrs. driving on the fun roads that are within an hr. of my house.
There are two other aspects besides what John S. listed, 1) know your mission and 2) know the road you are on. I spend a fair amount of time checking out new roads to drive on and in Mn near tht river there are plenty. I have had a few close calls and yes you can drift a 928 but you can also oversteer one if you lift off the pedal in a curve. These lessons have been learned while my mission was to drive as well as I could as fast as allowable. This is usually on roads I know well and have surveyed before.
If you know the mission is to learn the road rather than push it on it, you're alot safer. There is gravel in the same spot every time on some. I know it's there, but only from seeing it when I wasn't pushing hard
Just like in the military, when mission creep turns a recon into an assault. it's bad. - Ruf
Old Nov 25, 2003 | 07:43 PM
Donald's Avatar
Donald
Bernie-
Sorry if I misunderstood. When you wrote "have no idea what would have happened had I done what I instinctively would have done before by releasing the gas and hitting the brake." I assumed you meant that that would potentially induce oversteer and that you avoided it by getting back on the gas. I did not mean that you did, just that you thought those actions would.
Old Nov 25, 2003 | 08:23 PM
Randy V's Avatar
Randy V
25 Year Member
I'd like to see the pics - after all, it's not a 928, and nobody was seriously injured...
Old Nov 25, 2003 | 08:28 PM
Bernie's Avatar
Bernie
Talking
Originally posted by Donald
Bernie-
Hey Donald,
Yes, you should be ashamed of yourself making such a cavalier post.
errrrrr!
That IS what I thought would happen?
Ok, so I am going into a right hander too hot. Instead of staying in it and following the right line using power to get me through the turn, I opt to mash my brake and turn to the right through the turn.
what happens?
Won't my *** come around to kiss me on the lips?
LOL
Old Nov 25, 2003 | 08:30 PM
Bernie's Avatar
Bernie
Originally posted by Ron_H
I have removed the photos for the sake of the driver's security and privacy.
Hey Randy,
There were pics and then this.........
Old Nov 25, 2003 | 08:32 PM
Lizard928's Avatar
Lizard928
"Ok, so I am going into a right hander too hot. Instead of staying in it and following the right line using power to get me through the turn, I opt to mash my brake and turn to the right through the turn.
what happens?
Won't my *** come around to kiss me on the lips?"
Bernie, for this very reason porsche installed more front Bias than opt, to prevent the @$$ from coming around under braking in a corner,
Old Nov 25, 2003 | 08:39 PM
Bernie's Avatar
Bernie
I am confused?
Sounds like ABS for steering? LOL
Do you mean that I can't induce oversteer in a 928?
