928 Forum 1978-1995
Sponsored by: 928 Specialists
ABS "fun"
Old Jul 28, 2017 | 06:35 AM
gruffalo's Avatar
gruffalo
Default ABS "fun"
Hi all, my car's an '87 S4...
Ever since I drove it home in February 2011 I've been having an intermittent ABS issue. Recently the ABS light has become more on than off, until finally permanently on. I've googled and read up on the forums.
Symptoms are as follows: ABS light is on all the time, which points at the relay. First I checked the wheel sensors all Ohmed at approx 1kOhm. One more indication that the relay is broken. Then I pulled the relay. It was a 944.615.119.00 part number. Odd. This isn't the correct relay, is it? It comes up at a blower relay when googled.
Anyway, I opened it, and it was broken. Physically broken. The little spring that gets pulled when the coil is energized, was literally broken in two, and randomly rattling around in there.
The relay I had differs from a generic relay only by a 1k resistor between the 85 86 terminals. So I got a standard cheapo relay and soldered in the resistor from my old relay. (What is it for?) Popped the relay in and started the car. ABS light on for a few seconds, and then it came out!
My car failed the bi-annual inspection due to the ABS light, so I instantly headed down to the testing station got get it approved, now that the light was out.
But as I was about to pull in to the testing station the bloody thing came back on!!!
It turns out the only thing being tested today is me
I guess I just have to do some more testing to figure this out.
The correct ABS relay should be 92861512401?
Old Jul 28, 2017 | 06:49 AM
The Forgotten On's Avatar
The Forgotten On
The current ABS relay is 92861512403 as per Porsche supersession.
Buy it and see if it fixes the issue. Can't hurt to know you now have the correct part in place.
Old Jul 28, 2017 | 09:33 AM
SeanR's Avatar
SeanR
There are also 2 relays in the drivers fender inside the ABS unit. You have to pull your fender liner to access the cover on the ABS unit. Now if you go to change that relay and talk to your local P-car dealer, they will want to charge you a load of money. Roger@928sRus has an alternative to it that I've been using with great success.
Old Jul 28, 2017 | 09:49 AM
gruffalo's Avatar
gruffalo
Roger is on the case (at least I dropped him an e-mail).
I'll continue debugging shortly, thanks for all the input.
Old Aug 2, 2017 | 07:10 PM
gruffalo's Avatar
gruffalo
I did some more tests today.
Relays at at the pump are ok, and i cleaned the ground there.
The relay at the ce panel works the opposite way of what I expected. The coil is energized with the ignition off, and the relay shuts off when the ignition is on. Is this correct???
Also I noticed the relay (when on) would shut off for a split second and then instantly come on again every 5-10 seconds.
What controls the relay? Just ignition on? And what does the relay do?
am I making any sense here?
thanks
Old Aug 3, 2017 | 06:24 AM
gruffalo's Avatar
gruffalo
Default Jumping ABS relay, where are 30 and 87?
Reading this post made everything clear
https://rennlist.com/forums/928-foru...abs-relay.html
Since I don't have an ABS relay at hand, I don't know where to put the jumper wire...
Where's 87 and 30?
Old Aug 3, 2017 | 09:32 AM
worf928's Avatar
worf928
Originally Posted by gruffalo
Where's 87 and 30?
Look at the bottom of the relay.
Old Aug 3, 2017 | 02:30 PM
gruffalo's Avatar
gruffalo
As I mentioned in my previous post: unfortunately I don't have a relay.
Old Aug 3, 2017 | 04:13 PM
Simon928's Avatar
Simon928
Here's a pic from a generic "53" relay. You can see the markings next to the prongs.
http://www.audivw24.de/eng_pm_RELAY-...3B-15797_1.jpg
Old Aug 3, 2017 | 07:01 PM
gruffalo's Avatar
gruffalo
thanks.
I wonder if the post I linked to is correct, I can't make any sense of it.
latest news is that one wheel sensor had a short to ground. And Roger is sending me a new one along with a relay.
I guess I'll just stick to replacing parts for now, and stop trying to understand... 🤣
Old Aug 3, 2017 | 07:06 PM
gruffalo's Avatar
gruffalo
Looks like the pin configuration is different for the abs relay, compared to a 53 relay!
thanks.
Old Aug 8, 2017 | 08:08 AM
gruffalo's Avatar
gruffalo
I feel the need to close this thread. A lot of noise from me here, I simply couldn't make any sense of anything.
The embarrassing truth is that I was measuring at the wrong relay position. I had the ABS relay mistaken for the relay that controls the radiator flap system ('87 feature only). So that's the reason for all the confusing info from me in earlier posts in this thread. Silly but true...
Roger airmailed me a new relay and one new sensor in record time, and everything is now working perfectly again.
All my sensors ohmed correctly, but one had a short to ground, and that was it!
So the lessons learned are:
-read the relay chart carefully
-ohming the sensors to approx 1kOhm is not sufficient to verify their health. Also make sure they are isolated from ground.
case closed
Old Aug 8, 2017 | 10:41 AM
worf928's Avatar
worf928
I The embarrassing truth is that I was measuring at the wrong relay position. I had the ABS relay mistaken for the relay that controls the radiator flap system ('87 feature only).
Don't worry about it. Learn from it. Update your mental procedures and keep on keepin' on.
I've made worse mistakes in the vicinity of the CEL (on my own car not clients' )
Old Aug 8, 2017 | 11:52 AM
buccicone's Avatar
buccicone
case closed
Been there putting the ABS relay in the wrong spot. Put the relay in the kickdown relay spot on a 5 speed car. NO start!
