Strut differences troubleshooting
Team Owner
take your car to a 928 specialist let him have a look
Coach,
Are you 100% sure it's coming from the front of the car? Can you duplicate the noise without driving the car (ie. can you press down on the suspension and make the "crunchy" sound?)
Could bad wheel bearings make a "crunchy" noise only when going over speed bumps?
I notice that my lower control arm bearing rubber has been pinched by the mount. See the circled prt
Could this be causing a noise? Is there anything to do to lubricate this rubber? As far as I can tell, the rubber is not replaceable without replacing the entire lower control arm.
