Gauge problem
Gauge problem
I have big problems with my gauges. Alternator failure screwed up my gauges. The speedo is out but the Fuel gauge and Temp gauge are working. The Tack is still working but Oil pressure and Volt meter are not. checked the 14 pin connector, cleaned all contact points no burned or frayed wires. I cleaned all the conta for related fuses. I am wondering if my problem is in the is the printed circuit has failed. Are they still available. for a 1980 Euro S
Perhaps check the voltmeter light bulb, it should come on when the key is turned, and then go off when car is started. If that bulb is out, the whole circuit can be affected.
