For Sale: AIM SmartyCam SD, AIM RPM Bridge, AIM GPS Antenna, AIM CAN/Mic 4M Cable
For Sale: AIM SmartyCam SD (Sold), AIM RPM Bridge, AIM GPS Antenna, AIM CAN/Microphone 4M Cable
I realize the number of us tracking our 928’s is small, but if you do track your 928 and are looking capture data and video, I am offering the below. I am listing here before going to the broader HPDE Data forum, as I would love to have it go to another 928 driver.
Important and cool: This package is currently set up as a plug and play (Electronically) for 5-Speed 928’s.
Based on this post:
https://rennlist.com/forums/928-foru...ml#post8555759
I have tied the RPM bridge into a customized relay housing. Now, all you need to do is plug that relay into the empty XV (kickdown) relay socket in your CEP and you get full RPM, and switched power for the entire system ( RPM Bridge, SmartyCam and GPS). Works like a champ in my 86. Should work for any S3, not clear on other model years.
Here is video output of the entire system in use:
SmartyCam SD ( Has all latest firmware installed), SOLD!:
Includes an assortment of 8GB and 16GB Micro-SD cards and the Mini-USB Cord
Full Details here:
http://www.aim-sportline.com/downloa...am_122_eng.pdf
Important: This unit was “field repaired” two seasons ago. The mounting point on the bottom has been repaired with JB Weld. It is ugly but mechanically sound and held up for an entire season attached to a RAM ball mount.
AiM RPM Bridge (SMC Bridge), MC-539: $160
This kit allows you to connect your AiM SmartyCam (see above) to display and log RPM on any car -- even without an ECU or an AiM data logger! Simply connect the RPM Bridge to the wiring in your vehicle. ( per above, I have set this up for plug-n-play in a manual 928) The Bridge then connects to the standard SmartyCam CAN cable, allowing you to overlay RPM data on your videos. The RPM Bridge can accept a square wave signal (from an ECU) or a pulsed signal (from a standard ignition coil). It also has a built-in signal filter to "clean up" unstable RPM signals that can cause erratic readings.
The RPM Bridge can also be used to supply the RPM signal to an AiM display (MXL Display, G-Dash Display, or Formula Car Wheel).
Note: The RPM Bridge does not log any data itself, all data is passed to SmartyCam for logging.
External GPS Antenna for Original Smarty Cam, 4M Cable, Always Internally Mounted ( So not exposed to weather) MC-425: $110
This is the external GPS antenna for the second-generation AiM SmartyCam (Part No. MC-540) between 2009 and 2013. No setup required. Simply plug it into the camera, and it automatically does the rest.
The second-generation SmartyCam can be identified by the two round plugs on the back panel. The first-generation SmartyCam, with just one round plug, does not use an external GPS antenna. The SmartyCam HD uses a different GPS receiver.
SmartyCam CAN Cable with In-Line External Microphone, 4M, MC-545: $50
This special CAN cable plugs into the CAN port on the original AiM SmartyCam (2009-2013) or the current AiM SmartyCam HD Rev 2 (2015+) to connect to your AiM data logger, SMC Bridge, etc. An external microphone is incorporated into the cable. The input from this microphone automatically mixes with the sound from the SmartyCam internal microphone for enhanced sound. Measures 4M (13 feet) long.
This CAN cable has a 7-pin 712 (screw-in) connector on the camera end. It is not compatible with the SmartyCam HD, which has a 5-pin plug.
All prices do not include shipping, and are summarized below. PayPal or local pickup with cash. I am open to trades +/- cash for other AIM hardware or 928 S3 parts
SmartyCam SD ( Has all latest firmware installed), $299
External GPS Antenna for Original Smarty Cam, 4M Cable, MC-425: $110
Based on this post:
Full Details here:
Dr. Bob pointed out that my prices may have been lost in the noise, so I have enlarged them, and added them as a summary line. They are obviously all "OBO"
I am now using a SmartyCam HD with an Evo4.
Main goal is to capture additional health data, like oil pressure and various temperatures.
I also want brake and throttle data. With no CANBus or OBDII data, it requires creativity.
Also, just like to tinker.
Supercharged
Currently, I use Harry's Lap Timer with an external (Dual's XGPS160) GPS at 10Hz. For the other "health" data, I was thinking that I might be able to use the Innovate SSI-4 (which I already have on my GT) to capture RPM and upto 2 other 0-5v inputs like oil pressure or water temp and then add the Innovate Pocket logger to capture that data onto an SD card.
I generally use Race Render 3 to bring everything together. I generally have 4 cameras (Front, Mid, Rear, and now foot) and then add in telemetry data from HLT. THis would just be one more stream. The biggest pain is synchonizing the different feeds, but I think this would do it. And if it's all on an SD card, well... thank makes it pretty simple.
Ideally, I'd like to have a more "plug and play" system, but I think this would work really really well.
