928 Fuel Rail adapter
Hi All
I am about to finish the rebuild, but am trying to get some fittings for the fuel rail.
I am building a custom fuel rail and would like to keep the standard flow and return fittings attached to the car incase I want to return it to original at a later date.
I am after the 14mm nut and flared end to a barbed hose attachement (or something that I can adapt).
I have thought about cutting the Porsche rail and adapting it to a swagelok fitting, but before I do, would welcome any suggestions.
Glen
Glen
The best thing I've found for attaching the existing fuel lines to new AN hoses was this adapter that Greg Brown has:
![](http://928.jorj7.com/fuel/0825-115515-01.jpg)
It replaces the couplers on feed and outlet lines. I've used a swagelok fitting on the return side, which is low pressure. I don't know if I'd suggest using them on the high pressure feed lines.
I've also used these type of adapters:
![](http://928.jorj7.com/fuel/0825-122625-01.jpg)
Which I got from either Tim Murphy or BAT Inc.
George
90 S4 Grand Prix White (Murf #5 - 210 mph top speed)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
George
