Radio fit
Archive Gatekeeper
There are two different versions of the CR-1 used in GTS's, they vary as to whether they use 8-pin ISO connectors for power and speaker outs, vs. individual 2-pin DIN plugs for the speaker outs. Preamp outputs are the same 8-pin DIN.
Stefan at SW (or Massoud at Creative here on the west coast, depending on your location) can build you an adapter for either configuration but you should pull the old radio 1st and figure out which one you have.
ISO: (note repaired power connections, and the preamp outs were modified to female RCA jacks...)
DIN:
DIN:
Archive Gatekeeper
Here's a link to a post of mine RE: swapping a CDR220 into a '90 GT that had a CD-2, which mounts identically to a CR-1. Pop the bezel off the CR-1 (carefully, they're hard to find...) center the pins in the frame, pull the CR-1 out, and slide in the CDR-220. It mounts in the CR-1's cage without modification or need for a bezel.
https://rennlist.com/forums/928-foru...ml#post3387838
Where did you get the CDR-220? Was its display modified to work at the viewing angle of a 928?
Archive Gatekeeper
No idea, but I bet Stefan will know. His number is 732-522-1837.
Jim Corenman can alter your display to make it readable in the 928. He is very reasonable(just as a general rule, and also what he charges), fast, and the alteration done to the radio only involves the faceplate.
Archive Gatekeeper
Just put up the bat signal to him, he should be along presently....
See this thread for info: https://rennlist.com/forums/928-foru...at-a-time.html
I sent a PM with info if you want me too update the viewing angle for a 928, $20 plus postage.
Cheers, Jim
Cheers, Jim
