Quick jack
Ill probably get some blocks to go on the middle jack point, to give it 3 supporting points on each side or fab or buy the crossbeam adapter offered by quickjack. Looks perfect for our correct lift points.
The following 2 users liked this post by shortyboy:
Millermatic (01-17-2022),
Zirconocene (01-18-2022)
This I never knew was an option. If those middle pads adjust up high enough, it might work so the bar clears. Neat
944's are so easy to jack up and support that I don't see the point in using a Quickjack. I wouldn't buy one if I just had a 944. The offset lift points on a 944 makes jack stands and a traditional jack so much easier. I have a 5000SLX and never use it on my 951. I use the Quickjack all the time on my 911's and Ferrari since the jacking points are more difficult to deal with.
Whenever I'm in Europe, I am amazed at everyone's "pit"--the perfect diy setup for working under the car.
Not sure about you USA folks, but for some reason, pits are illegal up here.
Black Turbo: I see from your pics that there is a grey colored panel close to and "bolted"? to the inside frame rail, from the rocker panel? My '83 does not have this panel..what is it and what is it's function?TIA..
Maybe a slightly _longer_ version.
I believe these were available for the 951, S2 and 968. An aero panel for under the car. Not available on N/As I think. Either that or previous owner took them off.
Homes in California don't even have basements, which I really wish they did. As I understand it it's because of earthquake-impacted building code requirements.
