Using 951 clutch and pressure plate, 951 bell housing, and 968 engine....
Lifetime Member
Lifetime Member
So with the above, what flywheel would I use? A 951 bell housing will fit on the 968 engine I was told. Pretty sure that is correct. I'm going to use a 951 clutch and I need to know what flywheel to use (can I use the 968 flywheel?)
Ideas?
Thanks,
Matt
Ideas?
Thanks,
Matt
Nope, unless you plan to run 951 electronics. In a 968, one of the triggers is on the flywheel and the other is on the cam pulley. The only other vehicle that has that is 944S2, so you need a 944S2 flywheel and housing. Torque tube is same for 951 and S2.
