Best sequence for installing Steering Rack
I will give that some serious consideration. PowerFlex didn't mention it...
I feel like I'm getting close. Hoping to have the car on the road in the next few weeks.
https://www.powerflex.co.uk/road-series/fitting-guides
no better time than now. if you wait, it might wear the flutes on the inner bore of the plastic.
i've had a "depowered" rack (to the extent of removing all the lines and plugging the holes and greasing the rack internals heavily) for over 10 years...
but the "shimmed valve body" or however it could be termed from the xschop thread is something i've been wanting to try for a while too, that is the impression i am looking for.
my rack is OK but there is the predictable "free play" on center due to the slop allowed from the torsion bar inside the pinion housing which is what gets locked out by those shims/washers. steering effort is fine, i just want to get rid of the play.
Spencer, did you also remove the internal "piston" on yours? That's the part I think should make the most difference between the feel of an xschop style de-powered rack and one that's just been disconnected from the pump and plugged.
I'm sure you've seen my analysis of the way those spools work and why locking them is important, but I won't have tried it without locking them so I'm not sure I can give you much in the way of comparison.
I will, however, do my damndest
Yes, I had left the ground wire installed on the old cross member. It is being transferred to the brand spanking new (to me) LR three piece cross member first thing in the morning. I'll also be securing that equalizer tube with tie wraps.
I think, in honor of your finding this problem before I did, I'll take another picture of the completed assembly and post it.
My sincere thanks,
I use a Mac and Preview. Under the "tools" heading you can make those adjustments. I've found it's better to underexpose these pictures than overexpose them because you can pull out details like that in an underexposure. If it's overexposed, it's just gone.
Late to the party, but thought I would throw in how I did it. Like Otto there was no way to secure the universal joint to the steering rack with it installed and the crossmember bolted. I loosely installed the rack to the unbolted crossmember with tierods and boots in place. The clamp bolts are so short that even loosely installed there is next to no movement with both clamps in place. I then supported the crossmember/rack with a jack and slowly lifted it into place. I put some anti-seize on the splines to help it slide into place. The sweet spot seemed to be about 1.5" lower than the final position. After thread sealant and lower bolt being torqued the crossmember was raised and bolted lining up with marks made before disassembly. Last was attaching tierods to the knuckle.
Break out the GoJo...
Final photo of installed "de-powered" steering rack with new equalizer tube, ground wire and tie-wraps. Yes, I did hit both ends of the ground wire with De-Oxit during installation. Don't leave home without it
As I mentioned, the rack is installed on the Lyndsey Racing 3 piece cross member, which will give me easy access (I hope) when I begin the next stage of this project, which will be dropping the oil pan and replacing the rod bearings.
Next in line are the tie rod ends, followed by the new 30mm front sway bar & Delrin bushings. Then it's just a matter of re-installing the starter motor, clutch slave and the exhaust system and we're off to the races.
