Oil Pressure Sender instant failures.
Old 05-15-2017, 09:55 PM
CVR_Rally
CVR_Rally's Avatar
Originally Posted by marc abrams
First you need to establish a baseline to what kind of amperage flows through these sending units because I have no idea. You have two other gauges that work, temperature and fuel gauge. So let's use them. Disconnect both the temperature and fuel sending units. With a ampmeter in series from ground to the sending unit wire measure the amperage. Then do the same with the oil sender. I'm going to guess you are going to see a higher amperage on the oil pressure circuit cause by the oil pressure gauge itself. So you don't fry another oil sending unit, try installing a inline fuse on the oil sending unit until you find the problem. And besure that you have the correct fuse in the gauge circuit before you start testing.
I haven't compared it yet to other senders as I've started on the clutch.
However I took readings before I did.
1) Ignition on, engine off= 7.4v. .07 amps
2) Engine running = 8.71v, .09 to .1 amp.
I'd love to know what these readings are on a functioning unit.
Chris
(EDIT .09 not .9 and .1 not 1 amps)
Old 06-19-2017, 08:03 AM
CVR_Rally
CVR_Rally's Avatar
This weekend I was able to repair the issue at last by having time to run a new wire right from the point of connection on the cluster to the sender. Somewhere in the harness there is a short causing an extra line of 12v being sent to the sender and increasing the amps...that's why they were shorting out.
At least that's one for the win box.
Chris
Quick Reply: Oil Pressure Sender instant failures.
