Rescued 968
Rescued 968
So, I finally got my '87 928 S4 restored as my daily driver.
Time to get the junk yard find '92 968 underway.
Pics are of the car before any work was done. Believed to have had a TB fail.
Heads were sent out for total rebuild by previous owner prior to sale.
I replaced all timing components and dialed in a new variocam.
- Removed heads and verified rebuild
- New head gasket
- Front of engine service done.
- Built a new starter harness
- Rebuilt and flowed injectors
- Timing all dialed in.
- Belt covers installed.
Currently disassembled to
* Intake and Exhaust manifolds are off
* Starter off
* Fuel rail off
* Injectors out
Looking for advise or helpful tips on things to look out for or avoid during assembly.
Even a suggested plan of attack is appreciated.
I think I will work through the following order.
1. Test the starter at AutoZone
2. R&R power steering reservoir and hoses
3. Install exhaust manifold and connect exhaust.
4. Install starter and wiring harness.
5. Begin intake and fuel rail installation.
All advice is appreciated.
John
- New head gasket
* Starter off
* Fuel rail off
* Injectors out
John
While you have the intake off it's a good time to replace vacuum lines, the heater control valve and rubber hose and check the wiring/connectors for your speed and reference sensors.
Looks like this car is in capable hands!
You're in MD, too!
How did you find this car? Just happened to come across it while looking for parts for another car?
I really enjoy reading threads like this. The stories behind these kinds of cars are fascinating to me.
You're in MD, too!
