83 944 AC vacuum lines
My 83 944 AC still blows cold, as long as I am not at full throttle. (I am at full throttle often.) I have checked all the under-hood vacuum lines. I need to check the AC vacuum lines. How do I get to these lines? Is there an easy way, or is this going to be ugly?
All of the climate control vacuum lines are behind the glove box.
Start at the brake booster and follow the small line. The line should "T". One side of the "T" goes to the vacuum tank in the battery box, and the other enters the firewall and goes to a couple of solenoids. These solenoids control vacuum to the climate control system.
