On to the next project...seized nut on clutch master cylinder.
On the 83 the clutch master cylinder failed a long time ago. I'm finally up to that point on replacing it. Well wouldn't you know one of the bolts was so rusted 1/2 of it disintegrated and the rest has pretty much become one with the bolt.
Of course these have to be pressed/welded in bolts so what I will have to do is cut the bolt off then drill it out and use a new bolt to come in through the firewall.
I am guessing I can't be the only person this has happened to...
Chris
Chris
