Changed trans fluid, now grinds into from first to second
Interesting. Prior to this thread, I thought pretty much "all the cool kids" use Swepco 201. Apparently I need to do more reading...
It is GL-5, but seems to have a huge following, anyway...
Wouldn't reading the trans code off the trans be a more reliable indicator of having LSD or not?
Im using redline 75w90 gl5 in mine and no complaints. I debated on GL4 versus GL5 and opted for the GL5 for more shear protection. Its what I am running in my 993, so I decided to stick with it. On my 944 I have a LS, but didnt go with NS version but in retrospect probably should have. Sounds to me that the shifting issue could be syncro wear. I have the same problem in my 911. I learned to rev match my shifts to 2nd. I blip the throttle while clutch is in so that I am shifting at a higher RPM which helps a great deal. I am sure I need a tranny rebuild eventually but Ive been putting it off.
I'm using Swepco 201, and completely lost second gear for a few blocks on a cold start with today's 20F weather. Only a year on this fluid and it was like this last year too.
Once it's warmed up it's fine, but it's crap when it's cold. My trans is probably due for a rebuild, 140k on it and it doesn't seem like it's ever been apart. The LSD works when it feels like it.
What I have found works on both track and street , ( as well as most of my friends running vintage 944s and 911s ) is a switch to SWEPCO 201.
Southwestern Petroleum Company makes a very highly refined product which is just loved by Porsche transaxles or transmissions. There is no need for a friction modifier in using this product in LSD transaxles.... it's all I have continuously used since the mid 80's. No grinds, no missed shifts, no adverse wear on synchros or LSD componentry. No noise as in whine or chatter, and NO forced/hard shifts.
Just like slicing warm butter with a warm knife, but with rifle bolt accuracy and precision.
I've run Brad Penn in a 944, 928 S4, and VW Corrado VR6. In all cases, shifting when cold is as smooth as when warm, I'm a fan.
If you like Swepco 201 but want the cold weather performance that a synthetic offers, Swepco 202 is for you.
http://www.paragon-products.com/Swep...swepco-202.htm
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Same reason 911 owners with a G50/G64 don't run Swepco 201 through their box.
Whichever it was I used before it made the transaxle feel like I was shifting through mud. But I don't remember what was used it could have been the wrong grade.
As I compare 202 to 201, I'm starting to like 202 better... on paper, anyway.
Both score 1A on the ASTM-D130 copper corrosion test, so I wouldn't worry about them attacking brass/bronze. They don't contain active sulfur EP additives.
Not sure the same can be said of Royal Purple (4A/Fail).
Kinda surprised I haven't heard more about 202...
Originally Posted by mel
The Borg Warner syncros in the Getrag-derived 016 gearbox are happier with a synthetic lubricant.
If you don't like Swepco, then what do you like for a 951 M220 LSD?
I wanted to update. The Redline MT90 (which is a 75w90 GL-4 synthetic) finally got to my house today. I only had time to put the fluid in and take a 10 minute drive because we were heading out of town tonight. Right off the bat it seemed like a little bit of an improvement but as I drove it got better. I'm not sure if this was from warming up or because it took time for the new gear oil to displace the remnants of the old that didn't come out when I drained. The Royal Purple was equally not great cold and warm so it is still an improvement.
By the time I was done with my short test drive, there was no grinding but 1 to 2 was still a bit slow but could be eased in before revs matched perfectly; so better but not the same as before the initial change. I'll report back after I get a few more drives in when I get home in a week.
Yes 202 is a bit thinner. The usual 201 is 80w90 with -15F pour point, whereas 202 is 75w90 with -49F. 202 has a higher viscosity index (VI) = more consistent over temperature.
Not sure the same can be said of Royal Purple (4A/Fail).Kinda surprised I haven't heard more about 202...
Swepco 202 is synthetic. Still has friction modifiers for LSD. Moly is an added bonus. Naturally, 202 costs more.
I personally use 201 SWEPCO in my LSD-220 - 944 NAs, my 914 - 2.0 , my '89- M030 - 951 with 220 or LSD, and my '88 Carrera with G50 transmission.
I do NOT use it in anything newer, but go with the recommendations of the 202 SWEPCO.....
and as stated above: no issues in wear, noise, chatter, or balky shifting in any of them. Highest mileage 944 is 170, lowest is 28,000.
"like buttah"
I must try this. My 87S which has LSD is a bear to shift when the RPM is high. If I short shift say around 3500ish it's fine. No grinding but it is a PITA. When I took it to a track day last year it was like arm wrestling. Granted once I started to get used to where it wanted to shift I got better at it.
