FS:1988 944 DME/AFM $300 US
Old 12-16-2016, 11:32 PM
Noahs944
Noahs944's Avatar
Originally Posted by Jeff951NJ
One thing I forgot to say in our PM conversation is there are two kinds of "early" DME's. There are ones from 83-85.5 then 85.5-87. Make sure you have the correct matching set for the year of the DME and year on the AFM.
Jeff
Hmmmm... I didn't know that~so our 8 valve n/a cars used 3 afms and 3 dmes?
Old 12-17-2016, 12:03 AM
odonnell
odonnell's Avatar
Here's the skinny on the altimeter and the tach signal...
Altimeter plugs into the harness, right off the loom coming out of the DME. 85.5+ harnesses simply don't have this branch. You can run the early DME without it with no ill effects. So, non-issue.
The tach output is exactly the same across years, in fact, the tach triggers from the coil ground (DME pin 1). Another non-issue. As posted above, the only thing to keep track of is that the AFM matching.
Your issue with hard starts sounds fuel related. Have you verified the position of the FQS on the early DME? Perhaps the previous owner fiddled with it, and now it's too rich (throttle needed to start car). Maybe the FQS is ignored during cranking, but I'm not sure. The air temp sensor in the early AFM could also be going out, providing false air temps to the DME. There are tests on Clark's garage.
Old 12-17-2016, 07:49 PM
Noahs944
Noahs944's Avatar
Thanks Odonnell, was hoping to hear from you also.
Well, I put the 88 stuff that Jeff was buying & the car drove perfectly, all gauges working & no drama. The "other" ecm appears to have had some exposure to water & appears to have been opened a time or two. Before installing the dme I popped the seal off to ensure that it had a FQS switch. That plug was so secure that I doubt it had been messed with.
At this point I'm just assuming the ecm is nearly garbage, but I'll hang onto it as an emergency spare.
Quick Reply: FS:1988 944 DME/AFM $300 US
