DME inj drivers... myth or not?
Is it okay to replace injectors, for instance install 951 or S2 or S or early or late 8v injectors using the same DME?
I have heard it was bad to used early with late dme or visa versa because "hard on injector drivers"...
Any truth to this?
Any truth to this?
Rainman
You can use any year 8v-NA injectors with any 8v-NA computer.
There is no resistance difference (outside of the normal "spec" for low-z injectors that they are, 2.4-2.8 ohm). Mix and match to your heart's content.
951 injectors are 4.5-5.5 ohms which is unlike any other fuel injector in the known universe...why? No idea. But they are ~50% bigger in flow than the NA injector so they won't just "work" on an NA without being dialed in.
IIRC S/S2 injectors are high-impedance. They are closer in size to the NA injectors but still a little big. I don't know how they would behave with the current from the low-z driver feeding the high-z coil.
If you want to change to a different injector I wouldn't bother with an old Porsche part.
There are so many other, better, newer fuel injector designs from the 1990s and onwards in any flow rate/impedance you could wish for.
