Hot rodding the 8 valve cam housing
Old 10-02-2016, 11:15 AM
  #31
V2Rocket
Rainman
V2Rocket's Avatar
love your description there pers.
thats a long cam!
Old 10-02-2016, 11:17 AM
  #32
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by Otto Mechanic
Maybe I should clarify.
I've been looking at turbocharging a 3.0L block using a stock 2.7L head. From what I've learned so far, the 2.7L head is compatible (bolt on) with the 3.0L block and also the 2.5L Turbo hardware. I've been told (understand so far) the 2.7L head requires the Turbo exhaust valves in that configuration, I was only looking for confirmation.
You'd want the turbo exhaust valves there to deal with the heat, but they are the same size/flow potential as the stock 944 2.7 exhaust valves.
If you do go ahead with the build please share it here...the 3.0 stuff is certainly monstrous in power/torque output.
Old 10-02-2016, 12:02 PM
  #33
Noahs944
Noahs944's Avatar
I have used stock turbo valves for sale Otto if you are in the market.
I was going to use them in my n/a build but the profile seem more restrictive than the n/a exhaust valves, so these have been on the shelf.
Old 10-02-2016, 12:30 PM
  #34
jhowell371
jhowell371's Avatar
Longer duration makes for the nice lumpy idle in 60's muscle cars. I had a .550 lift and 320 degree duration Crane cam in a 396 Chevy. Longer duration loses you some low end torque, even more with a very free flowing exhaust system (open headers) in return for more higher RPM power. Trick is finding more usable power where you need it, be it high, low or mid-range. The 968 addressed this issue with variable cam timing.
Spencer, thanks for the lesson in valve lift in relation to valve size. I think the intake valves on the 396 were 2.12 inches so your formula is smack dab on for my old Crane cam.
Old 10-02-2016, 05:52 PM
  #35
924srr27l
924srr27l's Avatar
Originally Posted by 944CS
Based on my testing, experience, and the fact that a stock 944 engine has so many other hinderances to airflow - additional lift is the last thing it needs.
I realize you are looking for "free" horsepower, but it just isn't there in this motor.
If you want more power, you are going to have to change components. Air flow meter is the #1 start. Then Muffler. If you want to play with your powerband, you can mess with the cam, but the stock cam has a great street /daily driver profile.
When I first read your thread title, I thought you were going to talk about machining the cam box for a solid lifter conversion. This will allow a more aggressive ramp profile to the cam, which will help airflow.
Remember, peak lift will help high rpm breathing, but, this is a 2 valve head. High rpm and breathing physically aren't possible due to space constraints, when compared to a 4 valve head.
If you are thinking high rpm in relative terms(for example, if you want the engine to make power to 6500) this is possible with just a cam and exhaust change (recommended to replace air flow meter for maximum gains).
Interesting idea's, ......There is Horsepower to be had with this motor
I've had built a short stroke 8 valve 3.0 Engine with the stock AFM, different Cam and a lightweight smaller bore exhaust system which has achieved very good results
- 205 bhp @5799 rpm
- 205 ft lbs @4500rpm
it even has 190 ft lbs @ 2850rpm!
3.0 block
2.5 Crankshaft
2.5 cylinder head (Ported Inlets - Lindsey Racing)
Extrude Hone Inlet Manifold
Capacity 2707cc
Web Cams 274 Camshaft
Standard Bosch Fuel injectors / Pump & reg
Standard AFM / Coil / Dizzy / (1985 ECU)
So it's the smaller valved 2.5 head, not the larger 2.7 head
Exhaust bore reduced to 1.88" ID (1 box system)
8 hours of Live Rolling Road Mapping the 30 year old+ ECU
(This is the trick bit) optimising all rpm and idle / ignition values etc..
All for the street... Pulls like a Train,
http://924srr27l.co.uk/wp-content/up...924srr27L-.pdf
R
Old 10-02-2016, 05:56 PM
  #36
V2Rocket
Rainman
V2Rocket's Avatar
Old 10-03-2016, 09:49 PM
  #37
Noahs944
Noahs944's Avatar
Can someone tell me if the Porsche non turbo valve's head or stem is hollow or solid?
Old 10-03-2016, 11:22 PM
  #38
V2Rocket
Rainman
V2Rocket's Avatar
Solid.
Old 10-03-2016, 11:30 PM
  #39
Otto Mechanic
Otto Mechanic's Avatar
Thanks Noah, I picked up a set of sodium filled turbo valves when I bought the 2.7L head so I'm OK.
AFAIK (to answer a different question) the non-turbo valves are solid.
Old 10-04-2016, 03:44 PM
  #40
333pg333
333pg333's Avatar
- 205 bhp @5799 rpm
3.0 block
2.5 Crankshaft
Capacity 2707cc
R
Congrats. Looks like a great fun little car!!
Old 10-05-2016, 04:14 PM
  #41
924srr27l
924srr27l's Avatar
Yeah thanks, it's worked out far better than I imagined,
R
Old 10-05-2016, 09:26 PM
  #42
Otto Mechanic
Thanks for the confirmation, that's the plan I was working to. I'm still collecting parts for the build, the 2.7L head was a little hard to find but the fellow I bought it from tossed in the turbo valves with the head. I was pretty happy about that.
I most certainly will. I plan to start a 3.0L build thread once I get going. That's "Phase II" of my S2 restoration and I'm still not sure I'll do it, I need some track time with the mostly stock car before I do anything really exotic. In fact I'm thinking about buying a separate 3L short block and starting from scratch so I can keep the stock S2 engine as a spare, but I've gone ahead and beefed up the power train regardless. It will be ready for a turbo if/when I do it though.
I'm almost finished with "Phase I", which is to build the car to Firehawk specs. Maybe the end of this month I'll have it on the track.
Old 10-08-2016, 12:03 PM
  #43
Noahs944
Noahs944's Avatar
delete
Old 10-08-2016, 12:11 PM
  #44
Noahs944
Noahs944's Avatar
One thing V2 said that resonated with me; lobe shape designed with afm in mind.
so I dug into my old photos and found these:
Exhibit A:
stock later model to right. stage 1+ to left http://jonmilledgeengineering.com/product/s3-14/
Exhibit B:
stock late to left, middle: stage 1+ http://jonmilledgeengineering.com/product/s3-14/, rhs: stage 2+ [url]http://jonmilledgeengineering.com/product/8sr-14/
Indeed there is more duration with both the Jon Milledge bumpsticks. You can see the curvature is not as flat towards the toe (point) on his cams & the nose appears more rounded which will keep the valve at maximum lift longer. As I mentioned before, the stage 2+ (my term, JME calls this "3/4 race" also has more lift). As a daily driver the milder cam was far superior to live with.
Quick Reply: Hot rodding the 8 valve cam housing
