Help with 951 fuse box relay order
Hi. I have an '86 (May build date) 951. I am having trouble with the sunroof function. When I went to check the sunroof relay position of 18, the turbo water pump relay number was in position 18 and the sunroof relay was two position numbers right as in this photo. Both relays will fit either position. My question is, based on the photo, are my relays in the correct positions or do they need to be swapped? I can't find any pictures on the web that exactly duplicate the positions of my relays. Thanks in advance.
Thanks kindly. According to this diagram, my sunroof and turbo cooler relays were in the reverse order. I switched them but there is no response from the sunroof. I'm a little nervous to find out what the turbo would do without the cooler relay functioning.
For an '86 951 up to chassis 5920, the aux water pump relay goes in position G21 [where your sunroof relay currently is]. For the same chassis, the sunroof relay should go in position G18 or G19.
