The Rogue Tuning NA-Tune MAF KIT for the 944 8v is now available from Lindsey Racing. It's a little behind our original schedule, but now in stock and ready to ship.
When on that page, click on the product and there are additional pictures you can view and enlarge.
The main difference is we built the intake tube from aluminum. There is a machined flange we had to produce transitioning from a rectangular hole to a round for attaching to the tubing portion. That's where the slight price increase over Joshua's price mostly comes from. There was some software enhancements as well.
Mike or Dave Lindsey www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
A note for anyone that needs the 24 to 28 pin conversion, it is super mega easy. I did one for another lister and it was a quick job. If you can solder even a little bit and can read the instructions you will have no issues doing it yourself.
Lindsey,
Good job getting this worked out and onto market!
Are there any further changes to the tune vs the Rogue setup or is it mostly the same?
To all 944 owners...YOU WANT TO BUY THIS PRODUCT.
The driving experience is truly transformed...I gained more than 10% more torque at the wheels at the low end, the car feels so much stronger all around at any throttle position. Part-throttle cruising is so much better, and smoother...
The NA-tune MAF conversion is one of the top 3 mods you can make to a 944NA, period. (The others are the throttle-response cam and the offset camshaft key in "advanced" position).
Stock DME/AFM vs NA-tune...Lindsey, feel free to use this chart if you want.
I'm considering it this fall when I take my motor out for a full reseal. Already have a throttle cam and a 944MAX chip. Car runs great as is, but can't resist new toys. No problem for me doing the 28pin upgrade...very good with a soldering iron.
How seemlessly can you switch back and forth from one to the other (from early DME to late w/MAF and back)? I would need to do that for skog testing where I live.
That Al housing looks pretty 'chunky'. Wouldn't a FG or CF molded piece have been better?
This kit rendered my 944 un-drive-able. Life got in the way and its been sitting for months now... I suspect its user error on the chip installation. I gave it to a friend to solder in the extra pins and jumper wire since I am not versed in soldering and these DME's are not cheap. But alas, It might be ruined all together.
The car starts, but when I give it gas, it stumbles really badly, then kicks in if I give it a lot. Stalls after about a minute or less.
Wondering if anyone has come across this issue? I made sure the wiring was correct, and the car ran fine before the kit. I am just not sure what to do at this point.
Especially with all the rave reviews, and I feel like I'm the one "dud" out of the group :/
Takes 10 mins. Even less if you orient the airbox bolts so their heads are on the outside, versus the inside, when you are removing the MAF unit.
I swapped my car back to stock for smog in 10 minutes.
The target AFRs & Timing remain unchanged from the original kit...
The MAF filtering has been improved, as well as ISV-related action.
Every chipboard is checked before sending out.
Sounds like the person doing the soldering either incorrectly bridged some of the pins, or missed the jumper-wire... verify that the DME conversion was 100% correct.
Note, LR offers a DME 24->28pin conversion service.
Right, I don't think it was done correctly either. Just not sure what to do at this point. It looks correct as far as I can tell, but I'm not experienced with this type of work.
Wonder if they can take a look at my DME and the conversion that was done? Sourcing another late DME is hard and not cheap.
Take some high-resolution pictures of both sides of the DME board and email them to me - I'll take a look.
Not gonna lie, first thing I ever soldered, piece o cake.
Maybe so, but I was sure glad someone with more experience than me was willing to help a brother out! Thanks, again!
