Parts check for front reseal
I have an oil leak from one or more of the front seals. I'm about to change the timing belt anyway so I just want to make sure I get all the right parts first. Last time I did this (3 1/2 years ago) I replaced absolutely every oil seal including the complete cam tower set and all the metal spacers. I am pretty sure the cam seal isn't leaking, but I think it's coming from at least the upper balance shaft (maybe both). I was thinking I should get:
* both balance shaft seals
* onion skin seals
* crank seal just in case
Is there anything else I'm missing? It's been leaking since very soon after I did it, so I'm assuming there's no way the metal spacers could have worn that quickly?
* onion skin seals
Proprietoristicly Refined
3.5 years is a short time to have to replace FOES. Could be a turbo thing?
By "metal spacers" , do you mean the races?
Did you replace the 2 races on the balance shaft 3.5 years ago? Or the camshaft race?
The oil pump seal will also leak if the front oil pump drive sleeve has even a minor slight groove.
Just ideas.
GL
J_AZ
Just ideas.
GL
J_AZ
Attachment 1052001
Just ideas.
GL
J_AZ
Attachment 1052001
Just ideas.
GL
J_AZ
Yes the metal spacers I was talking about are the metal pieces that go on the balance shafts etc. I replaced absolutely all of those metal pieces, including the oil pump drive, and every wiper seal, o-ring, onion skin seal etc. I used the Paragon kit that includes everything: http://www.paragon-products.com/Fron...101.000.02.htm
Actually they have a handy breakdown of all the parts on that page so I will use that figure out which ones I need.
