Finished A-pillar pod (PIC)
v944god - Boost is hooked up, water temp not hooked up at sender end yet, awaiting sender install.
Duke - The water temp is gonna be hooked up to the temp sender supplied with the guage that is gonna be put into the water socket
(peice that has bleed screw in it) after I drill and tap a hole for the sender.
